Version 19.19 has broken the backlight auto-intenisty control
Update: 19.22 released, the issue is still present..sigh...
Update: 19.21 released, the issue is still present (thought it seems the "goes compleetly dark" timeout is longer).
Ever seince my Edge 1040 Solar has been updated to 19.19, the lowest "auto" backlight setting is "too low" as it completely shuts off the screen's backlight, rendering it useless.
The issue is not with the sensor as it does turn the backlight on if I flash my healight onto the screen and we do see the intensity auto-adjust depending on brightness of light source (drop-down menu, you see the intensity setting increase/decrease).
I most definitely did not have this issue with the previous release, this only started with the 19.19 and has been going on for multiple rides. The unit is powered off every time I start a ride (given the sensor detection issue has yet to be resolved......)
  • unfortunately I can confirm the bad behavior also with the latest sw
    - set to auto -> it goes to very low brightness
    - auto to OFF, manually set it higher -> OK
    - set back to auto -> it goes to very low brightness
    - toggle auto to OFF -> it stays on the auto level, it does not return to the previously manually set level
  • I can confirm the same behaviour.
    I've also noticed that the darker the ambient light the darker the screen becomes so therefore on a bright sunny day or if you shine a light at the sensor the auto setting increases the backlight to high.
    Shouldn't the auto setting turn the backlight off on bright sunny days as it is not needed and it will use more battery?
