How to "Enabled manual setting of Resting Heart Rate to enable Fitness Age calculations on Garmin Connect"
The updates for version 191.19 say you can set the Resting Heart Rate manually.  I was hoping for this but am unable to find where and how to do this.  Any one have an idea?
  • Su edge 1040 devi andare su statistiche personali ,poi su zone allenamento  quindi apri finestra zone di frequenza cardiaca e dove vedi scritto riposo  metti manualmente la tua fc a riposo
  • Thank you for your reply.  That will allow you to set you resting heart rate for automatic calculations of your Heart Rate Zones. That option is not new.  However, that value is not being used for the Fitness Age calculations.
