With the 19.x Firmware I experience the following problems:
- maps on the edge aren‘t available in basecamp anymore
- maps can‘t be transferred anymore from basecamp to the 1040
Please fix it asap
Since peggatsch reported (thanx do him) that it works for him, I did the following:
and now for one reason or the other it works as described by peggatsch above -it seems the problem were the "old maps"
We need an GarminDevice.XML backup from anyone still running 18.25 firmware. Overwrite with it the one that is on your device each time after conneecting to PC then transfer will work. I have used one from Oregon 600 and that works for 4GB limit/sending maps/deleting maps but it does not tell Basecamp to convert GDB/GPX files to fit files.
I tried editing the 19.19 created file but couldn't get it to work.
I've removed some lines - and it works again. Maybe it's too long?
I uploaded a working version here: https://openmtbmap.org/GarminDevice.xml
Right click - Saves as and choose the Garmin folder of the Edge 1040.
Hopefully Garmin fixes the firmware to create files again that are readable by Basecamp. My version works - but needs to be replaced before every time you use Basecamp or MapInstall.
Could you tell us what you cut out as I would like to reproduce the issue and solution?
