When you say reset, do you mean remove the light from the network, then add it back? I've manually done this a few times already. The light will only charge with a 1A charger.
i reset the unit resetting the light network. re pair work for 2 charging and stick again at 3 bar !!!!! i did it from the start and work again !!! any help ?
