My gear:
Garmin Edge 1040
Shimano Di2 DuraAce 9200P with power meter
Before my cycling activity I fully charged my Edge 1040, my power meter, and the Di2 battery. I also zero calibrated the power meter.
Every once in a while my average cadence is higher than the maximum cadence, I also get erratice max cadence readings as high as 250+ cadence which no "normal" human cyclist should be able to pedal... (this happens on average with 1 out of every 8~10 rides):
https://connect.garmin.com/modern/activity/12161758287
I have opened a Garmin tech support to report the bug.
Any info on why this is happening is appreciated.
Thank you -- Cameron
