There is only one keyboard whith device language keys and no english keys. Group ride code generates in english and its imposible to serch them.
ekhagman so this is when your edge is on a language other than English, and someone shares with you a code generated on the English language setting (i.e. someone whos edge is in English made the code and shared it with you to join the GroupRide)? You are finding that the only option is to temporarily change your language to English?
7859287 so this is when your edge is on a language other than English, and someone shares with you a code generated on the English language setting (i.e. someone whos edge is in English made the code and shared it with you to join the GroupRide)? You are finding that the only option is to temporarily change your language to English?
1st device with non-English setting (1040). 2nd device with non-English setting too (Explore 2). Both of them are with russian interface.
-Explore 2 creates GroupRide and generates code with latin symbols and digits.
-In 1040 I want to join this GroupRide by entering this code and I see only russian keyboard and digits.
-If I change system language to english I will see latin keyboard while entering this code. So I can join GroupRide.
-If I create GroupRide by 1040 I will recieve the same problem while entering code at Explore 2. Only changing system language helps to join to GroupRide too.
P.S.: I created this post at Explore 2 forum too.
Thank you - I have opened a ticket on this and added you to it. For anyone else experiencing this please send me a message stating your location and language and I can add you as well.
