1040 Solar turn by turn
Hi,
My wife has an 800, and we've done the same ride together several times.  I follow her as she's doing the navigation.  I decided to save that as a Course and ride it alone.
I load the course, and it asks if I want to navigate to the start. I say yes, then I think I click Ride, and off I go.  Except, nothing happens.  If I go to a map screen, I can see barely visible arrows hinting which way I should travel and a section at the top of the screen that is solid back - probably where my directions should be.
I get about halfway through the ride, and it loses the course.  This has happened twice now.  I ask it to take me home by the shortest route, and there is a message along the lines of no navigable routes found.
I'm on version 17.29.  Below are the maps installed.
I'm sure this is user error, and would appreciate some advice.
Thank you
