Screen layout for 8 fields
Hi
Is there a way on the Edge 1040 series to create a simple 8 field layout, with  4 row / 2 column layout? In other words a simple table with every cell the same size?
There is an 8 field layout but it only exists with the top two fields being larger / full width which means the remaining 6 fields are smaller.
Thanks
Pete
  • Search in ConnectIQ if there's a plugin to do this. If there is one, then download it. Then on the data screen where you choose how many fields, choose "1" and choose the "ConnectIQ" type, and choose the plugin name. I did something similar for the Map Screen where I used "Map Dashboard".
