1040 Solar et Sram AXS
hello, I have a bike equipped with Sram AXS, I have configured the sensors and everything is working perfectly, I have also entered the size information for the 35/48 chainrings and the 10/33 sprockets, but I have 3 different pairs of wheels with different cassettes 10/36 and 9/46, how to add this data when I change my wheels. thank you in advance for your help.
  • When I change out my wheels from 10/36 to 10/33, I update the info in the SRAM AXS app. I haven't had to do anything on my 1040 Solar.
  • Hello, thank you, that's what I did with my old Hamerhead Karoo2 counter, but how to sync SRAM data with the Garmin counter, I couldn't find anything similar :(
  • Go to the Sensors screen, select the SRAM AXS, then Sensor Details.
    Tap on Rear Gears.
    You can select a Preset or Custom from there and manually enter each cog.
    Unfortunately, there doesn't seem to be a way to build a profile for wheelsets. Maybe someday. I have a Karoo 2 as well. I can assign a bike and sensors to a profile, but I haven't seen a way to build two distinct profiles for the same sensor. I haven't really looked for it either because I usually only switch out the wheels between summer and winter riding seasons.
  • That's what I thought, it's an error on Garmin's part and I hope they will correct this deficiency in a future update, I already regret my Karoo2 especially since the Karoo3 will be released shortly, I regret my so-called top-of-the-range purchase :(
