Hi,
I just had my first ride out with my new Edge 1040 Solar and the entire experience was kind of disappointing. I used to ride with a Teasi One 3 before which used to work way better out of the box. I'm hoping I can tweak some settings here or find out if I did something wrong.
Let's go through my "workflow".
I plan my bike trips using komoot and wanted to use the Edge to keep me on my planned track. I expected the Edge to be more accurate and being able to guide me for several days without needing to drain my phone's battery. Also getting me out of the deepest jungle when I don't have an internet connection.
I have connected komoot and my Edge before, but otherwise I haven't done anything with it.
Connect IQ Komoot app issue:
I would consider this more of a komoot issue, but I'll mention it anyway:
I sent the planned route to my device. I see it in the Garmin komoot app. There is a "Start" button, but it didn't work (it worked now when re-testing it). So I was looking for the route in the system and found it in "Saved Courses". Along many other random komoot courses from years ago. I have no idea why those were synced to my Edge and why they keep resyncing even when I delete them.
Now, my main issue:
I started the navigation from the system and saw my planned route on the map, but that's all I get. I expected to see turn instructions, highlights of the path I need to stay on, maybe automatic display brightness changes when it's time to take a turn, but nothing. Just a red path on the map which is somewhat visible under good light conditions and hardly detectable when the Edge is in the shadow.
My Teasi used to tell me in how many meters there is the next turn. The display changed to maximum brightness when I arrived at the place and the relevant segment was very clearly highlighted.
Not really any better:
As soon as I deviated slightly from my planned path I just got a "Route calculation error".
