Can I turn off the edge during mid ride?
Hi All,
I am planning to do some long ride (1000+km).
Is it possible to turn off the edge after I finish the rider in the day time and turn it back on the following morning when I resume the ride?
Will this have any ill effect on the data recording? Or should I just record the ride each day and then just use some app to join them together to make it a single ride?
  • Saving and stitching together is a good idea. With that being said, when I use it for commuting, I pause my ride change the screen, so I don't accidentally delete it, and then power down the unit. When I turn it back on, it's right where it was if I shut it down so, yes, you can turn off the unit and it'll resume from wherever it was.
  • Thank you all for all the feedback. I will sure to test power down after the ride and then resume later on before the actual big rider to see how the edge unit handle it.
