Anyone else get a featureless map after the 16.11 update on a 1040 solar?
Hi TeamSpecialized, Here are a few things to check:
Thanks for the help. While I dont have the map "Cycle map North America is 2022.20” you mention, I do have "Garmin DEM Map North America 2022.20” and “Garmin Cycle Map NA, US 2022.20”. Map is looking better. Question: how do I remove unneeded maps? Cant do it in the unit, perhaps a folder within the Garmin folder?
You will not want to remove either of those maps. Sorry if the way I wrote that was confusing, I meant that your North America (NA) map should be version 2022.20, which it sounds like yours is. The DEM map is a Digital Elevation Map so you will want that as well. The 1040 has enough space on it to hold several maps so you should not have to remove any.
Yes it is 2022.22 and I wont remove anything. But I see no reason to have Africa maps on my unit. LOL Thanks for the info and help
You can use the map manger in Garmin Express to de-select the regions you no longer want installed.
