multiple structured workout on same day
Hi,
I noticed that if I have multiple structured workouts (created via TrainingPeaks) on the same day, only one shows up on the Edge1040 Trainingplan.  The calendar on Connect does show all structured workouts for a given day.
Any idea anyone?
  • I also have this problem, plus the correct workout is not always displayed. Sometimes the next day's training is displayed or not displayed at all
  • I also often experience the next day's training being displayed.  What seems to work is to select the workout not from the 'homescreen' but from the Trainingplan menu. I did that for the last 2 days and it worked.  Granted, the sample size is too small to consider that a reliable workaround.
    The main issue though persists: for days with multiple workout plans, only one is available on the Edge1040.  If anyone from Garmin is reading this, could you please add this bug to your backlog?
  • If it displays bad training, a restart usually helps
  • I discovered that the next workout on the same day appears on the Edge 1040 after completing the first one and then forcing a Wifi sync.  So far so good.  Unfortunately, the order in which the workouts successively appear on the Edge is not driven by the planned start time, sequence in which they were created or title. It appears the Edge picks up the next workout from the list visible on Connect.  Unfortunately, I am not aware how to change the sequence of workouts for a given day on Connect.
  • Hi @garmin do you plan to fix this one? it works on Garmin Fenix 6 that two trainings are available to choose without any workarounds.
