Now that Garmin owns Tacx, I am wondering if we will start to see better integration between the Tacx App and the Garmin devices?
For example: If I record a ride on my Garmin edge 1040, while using the Tacx app to follow a movie/workout, the elevation data will be missing from the ride. If I record from the Tacx app, the elevation data will be there, but the cycling dynamics, stamina, and respiratory rate are missing.
The only "solution" is to dual record the activity using both the App and Garmin device, but then we have duplicate entries in our activity logs, which again is problematic in its own way.
Why can’t the Tacx app do/record everything the Garmin Edge device can, the computers that the Tacx app runs on are far more powerful than whatever is onboard the Garmin devices. Does Garmin plan on adding all the features of the devices into the Tacx App over time? The other acceptable solution would be to find a way for the Tacx app to stream/send the elevation and speed data to the Garmin Edge device. There should be better integration.
