Intensity minutes target not syncing with garmin connect
Has anyone else got an issue where you have set a higher target of intensity minutes in Garmin connect, ie 500min for me and the edge target is still at 150min? The minutes are reflected correctly on the edge just the target remains the same and doesn't seem to be updatable.
Thanks for your help
