The Edge 1040 still makes alert sounds after you disable Tones from the System menu while an activity is in progress.
That’s because they are set from the sensor settings. Just go to the sensor details and stop them from there. Probably makes good sense to disconnect them from the main tones settings as it is a “safety” feature. Your probably more likely to want to keep them and not the others.
Thanks, I looked at the sensor details as well, but I must have missed it. I'm looking for some way to disable the radar when I'm stopped. I can't turn it off, because it won't re-pair fully when I turn it back on. I can't turn the Edge itself off because of multiple issues due to power cycling the device during an activity.
