Hello,
Using the Mountainbike-Trail Navigation feature the position setting by "Use map" does not work.
How to cause the failure:
1. MTB Trail Navigation
2. Select Trail Network
3. (Map) Setting Pin on Map, Select
4. Start Location is showing "Current Location"
5. Pressing Start Location: Use Map. Setting Pin on map. Select.
6. Start Location still show "Current Location"
The route calculation hangs on Route 2 but will not finish. Abort will cause the message a calculation error.
Before it was possible to set the position by the map and route calculation with a chosen trail worked (leading to 3 suggested routes).
Resetting to factory settings will solve the problem for a certain period but the problem appears later again.
Anyone else with this bug?
