Can anyone help with this??
Hi all,
Does anyone know how to get the DEFAULT LEADER Priority to work?
This is under
Training
Strava Live Segements
you pick your order and I have GOAL first, but always get PR showing first at the top when a Strava live segment appears.
I know the segments have goals set because it actually shows it when I flip the arrow to it but isn't there a way to get it to ALWAYS SHOW GOAL first?
I have tried everything. bug?
Thanks
  • Hi @weatherall,
    Problem still exists. I think I recall 1 segment appearing as GOAL right away and this segment was on a trip this weekend, not a local one that I have tried out 20 times. This is important as it may be related to what you said about "When the segment is first loaded."
    I am trying to test this but can you please explain what you mean by
    "I think the default may only get applied when the segment is first loaded"
    I followed your steps about the files etc as you know and did not change.
    Thanks.
  • A2weatherall,
    It looks like they fixed it!!!!!
    Now in Beta v 14.15  there is a green vertical bar next to what you want showing first. You go into EACH strava live segment hit leaderboard and pick which one you want to show first.
    It works- thanks to you!!!
    Barry
  • may have spoken too soon!
    Went for a test with the car and 1040 and it worked on all of them. They showed GOAL first.
    Worked on segments during the day on the computer and went for a ride and some still showed PR.
    Do not think we are out of the woods yet, but getting closer.
    I'll update you.
  • I need to try and find sometime to look at this. Maybe this weekend  if I have time. There are a lot of moving parts.
  • Appreciate it but give me some more time to test and explore. I am making progress and learning more how it works each day.
    For sure having segments goals BEFORE you change default has something to do with it. But I would not say it is totally that either.
    I did notice that now that I have GOAL as the first on default list when a new one is made goal is first but whether that always shows up first on ride is another story.
    You are right- so many moving parts of which I think 1 or 2 are not working as intended.
    I'll keep working on it. You have other things to do.
    I'll update you.
    Thanks
    Barry
