Heart rate lag
Hi,
on my 1040 I see everytime I ride a heart rate lag on the display. In the beginning the heart rate is the actual heart rate but after a few minutes the heart rate lags behind. Maybe the same lag as the grade lag, but I don't know. The lag can also be seen in the .files. Also I have tested the 1040 against my Edge 530 and there you can see clearly that this is not as supposed. I have attached a photo of this behavior where you can see the power and heart rate graph. Power is connected to my Indoor trainer and heart rate is coming from a Garmin heart rate strap, connected over BLE to both units. On the 530 (upper unit) you can see that the heart rate rises every time I kick the pedals and apply power. But on the 1040 (lower unit) this heart rate rise lags clearly behind and I don't know why. Is this maybe a known bug or discovered anyone else this behavior? I'm on firmware 12.16.
Maybe you have some ideas here. Thanks in advance!
