Would you expect a low battery level warning on the 1040 for the Rally xc200.? I have lseen los and critical for my varia, but my peddles died last week without warning
Julian
Julian
Thank you for everyone's discussion on this experience. This is now under investigation and we will update this thread when possible.
I had my Rally XC’s die without warning this week. The sensor record in Garmin Connect showed battery OK on Aug 13, but on Aug 20 the pedals wouldn’t even connect. I never saw low or critical battery warnings…
My Rally XC200 (on firmware 4.00) also died without warning this week. According to the Rally manual you should get a low battery warning so it would appear this is a bug - though I'm unsure whether this…
You should get a low battery warning during the activity if the battery drops to that level. It should also show in teh ride summary.
On the device, if i go to History -> activities -> specific_activity is do not see any battery information for any device other the a 1040 solar report which just shows the gain and intensity, but not the devices charge level or any sensor.. Is this the correct place to look?
on the web version of garmin connect. i see the the xc200 on the right has side. in the ride before it was there and said battry ok. the next ride it dies after 2:48:58. and is no list on the right had side of that report.
I had my Rally XC’s die without warning this week. The sensor record in Garmin Connect showed battery OK on Aug 13, but on Aug 20 the pedals wouldn’t even connect. I never saw low or critical battery warnings. I pulled out the batteries today, and both measured a fraction of a volt (i.e. dead). So did the batteries go from OK to dead in a week without being used?
Installed new batteries and pedals seem fine now.
My Rally XC200 (on firmware 4.00) also died without warning this week. According to the Rally manual you should get a low battery warning so it would appear this is a bug - though I'm unsure whether this is unique to the Edge 1040 (I'm on firmware 14.20) or specific to Rally v4.00.
I have this behaviour (no low battery warning) with my Rally RS200 (rel 4.0) too (on both an Edge 1030+ and an Edge 1040).
My previous ride (using an Edge 1030+, rel 6.40) shows on the activity page in Garmin Connect (web version) that the battery are OK (full green). During this ride I did not got any low battery warning what so ever.
The next ride a few days later (with an Edge 1040, rel 14.20) the Rally RS200 would not even connect to the Edge 1040. When I installed new batteries, the RS200 connected without any problem. When I put the old batteries back again (for a test) the RS200 would not connect.
So, I didn't got any low battery warning and suddenly the RS200 batteries were dead.
The same issue for me today.. XC100 died with no warning:
https://connect.garmin.com/modern/activity/9661738669
After putting new battery, everything works fine!
