Where is the "Manage Maps" button?
I did see the button option when I first connected to the Garmin Express but no longer there subsequently. How do I make it available again? I need to delete and add maps.
  • It your Edge connected with Express? Can you attach a picture?
  • It worked when I tried it on the Windows version and it wasn't working on the MacOS version. I found the PC version more stable.
    Thanks for your response.
  • I understand if you have a personal preference of one OS over the other, but this feature should function the same regardless of version. Are you still seeing this issue with your Mac version?
  • I checked back on MacOS version and the button appeared again. However, I did find they have different behaviour. When I click on Map details on the Mac version, it shows 3 maps installed but on the windows version it shows 5 installed.
  • I'm using Express on Mac. I've had some strange issues. I loaded all the available maps onto the device but the device wouldnt display any map data (none at all) until I went back to Express and removed APAC and EU maps, and then the NA maps suddenly showed up on my device. I also noticed that it was showing (0) maps loaded on the left pane even though it simultaneously showed all the maps being loaded in the right pane. Once I removed the maps and added them back it showed an accurate count.
    I havent tried any of this with Windows. For the moment the Mac version is working.
    Being frustrated and constantly troubleshooting is a central part of the Garmin user experience.
  • Yea I encountered the same thing too... Pretty weird.
