The varia radar is very often disconnecting and immediately reconnecting.
Always followed with a beep.
This is tested with old RTL-500 and newer RTL-510.
I have the same problem. It makes me extremely irritated. It happens often.
I also have the 515 and unfortunately, deletion/adding hasn't changed this behavior on any firmware up to and including .16 that is installed now.
I'm jealous that it fixed it for you!
Good Question
I checked now and seems to be ANT+
But when I transfer the sensors from 1030 to 1040 , I had the same problem, and even worse, I had connect and disconnect in the loop
I am wonder if something matters if you close the radar and reopen (manually ) or leave it open and have the Garmin open the radar based on the activity
I just double-checked. Mine is also ANT+
Is there any reason to think BT would be more stable?
Did not tried , not sure if radar can be connected over BT or not to Edge, if yes , then you can try
The only drawback it can drain little bit faster Edge battery
i don't know if ant+ or bt will be more stable. but if there is an issue, after deleting and re-pairing my next try would be changing the transmission standard...
The radar unit will only operate over ANT+ with the Edge. The BT connection is only supported for use with that the GCM phone app and that only came in on the RTL 515/516.
