After 10 Days Bicycle Holidays with the 1040 Solar - Bug 3 - Changing Map Zoom
Autozoom is switched off.
When changing zoom, after some seconds it jumps back to original zoom level.
bug fix: immediatly after changing zoom level you have to swipe to another screen and back to map.
  • Thanks for the temporarily fix
    I think this was already reported and my presumption is that will be fixed in next FW release
    Somehow I had the problem while chasing Strava segment ( and I was following Virtual partner on the map) and changing the zoom, and Garmin changed the zoom back , although autozoom was off , very annoying , because I did several time, and actually I did not know the segment and I need to follow when I need to turn back (it was like a loop)
  • Yep, I've also encountered problems with the Edge 1040 changing the zoom level for me even when all auto-zoom settings that I can find are turned off. Hopefully this will be fixed soon.
