Once you stop and you have the unit pausing, it’s almost impossible to change pages because the “pause “ sign keep showing up making any adjustment you eventually need to do, a painful process . It would be nice fixing it.
Yes correct. Don't like it as well as DI2 buttons don't work at that stage while DI2 buttons worked well on Edge 1030 when pausing.
Thing is that when pausing you cannot us the map which is really…
Aweatherall, no it wont, you need to tap twice, as the first one will show you the home icon. And then you must keep touching the screen so it does not reappear.
there's no need a pause icon when I stop…
You are absolutely right. It’s one of the issue plaguing the 1040.
Thing is that when pausing you cannot us the map which is really anoying here.
Therefor Garmin should leave that as it was on Edge 1030 (+)
Ronald
I sell my 1030 and buy a 1040. Big error, this pause sign on screen it’s a pain, you can not read or use the garmin.
Tapping the screen will remove the central part.
there's no need a pause icon when I stop, or do you need garmin tells you that you stop?
Valerio, guess you are same guy on facebook group...
I just call garmin, talk to help center and send a video showing them how annoying is that pause icon... hope they understand and remove ir from next update... on 1030 there was not that icon enter DIM backlight when I stop my ride, also my auto-stop is OFF, so I do not understand actually what's for auto-stop...
on my facebook post I talk about 2 problems, but guess I need to ride and rec a video to show it. I will post it on facebook group and here very soon.
Yea I am the same. Thanks for putting so much effort in order to fix all these bunch of issues
