[Problem] Map Screen is empty before GPS Lock
Right after starting up the 1040, the map screen is empty until it accquires GPS lock.
  • That seems reasonable. If the 1040 doesn't know where it is then it doesn't know what section of map to display.
    However, I can't see this as a big problem as I've been impressed by the speed at which the 1040 locks onto satellites and has a location.
  • Yes, I'd agree to that it seems normal but I had the 830 and it always displays the map portion of my last known good GPS position.
    Imagine, I could scroll around the map had it appear before it get a GPS lock and be able to find a spot for navigation before I go outside.
