Making sure Garmin routes my Komoot route exactly as made
Hi there, helpful friends.
I'm planning my participation in a multi-day ultra race. I use Komoot premium to plot my route. During the race there are so-called parkours I need to ride every single meter of. These parkours are specified as Komoot routes by the race holders.
I'm concerned what happens when I use my Garmin Edge 1040 Solar with these parkours. Making a shortcut (or detour) would techincally disqualify me, so I need to make absolute sure that they follow the routes down to the last meter. How do my settings need to be to make sure the Edge is not taking liberties and trying to outsmart me? I need it to not reroute me from the route at all, no matter the obstacle.
Thanks!
Sincerely, Ketil
  • Around Slany is correct. I had a bit of freezes in the parkours of CP1 in the Czech Republic, but nothing as bad as the day after around that exact area.
  • Last 3 beta's fixed a lot of bugs
    If Garmin will ever fix climb pro "functionality "to not often finish100m before the real end of a climb" then I will declare this as best device ever, but its not there yet
    My believe is that the drain behavior in climb pro page is normal as it must process a lot of information, and my feeling is that if they will make the percentage more accurate , then the battery will drain faster
  • In the last beta they fix some issues with some locations in Europe , hopefully that will fix also your problem
