Personal Stats not syncing.
Hi,
So, I've moved from 1030 plus into 1040. However,  despite of choosing syncing all the data including profiles, sensors and data only my personal info sensors were synced. All my stats, ftp (entered manually), training load, vo2max, recovery time... were not synced. Pensive
Is there any way to force sync that?
  • Check that Physio true up is enabled.
    Goto My Stats - Training Load -> Select the 3 dot menu top right
  • Did not help. :/
    However, I've found ... sort of... a workaround. I've simply copied over the activity fit files from my 1030 device (which has been replaced by 1040). After doing that I can see my training stats again.
    BUT... yeah... it seems the FTP calculation is somewhat broken or maybe my workaround caused some issues. I've had a ride today afternoon and 1040 calculated my FTP lower by 30W than before. So the chart looks like this now :) [It's in Polish].
    And the strava stats from my last ride that caused that:
    That's somewhat not really right. I've started regretting buying 1040, for now, I'll switch back to my 1030.. I guess.
