Hi,
I used to ride with my Wahoo Elemnt Bolt but was missing a couple of features, like lights management, sync to Garmin Connect, Climb Pro and a larger device. So I recently bought a 1040 and tried it for some time. This is what I experienced:
- I almost died a couple of times during my commutes to find the right menu. Why do I need to have a masters degree to understand the logic behind the menu structure? Example: To turn off sounds, it is not enough to turn off sounds but I also have to turn off the turn-by-turn prompts in courses.
- I am using RideWithGPS routes. They just sync to my Element Bolt. Not with the 1040. I need to unpin-snyc-pin-sync. And when I change a route, I need to unpin-sync-pin-sync again. Very annoying.
- Turn on lights during a ride (without an additonal IQ app)? You have the switch in a car directly at your hand. But on the 1040? Swipe->click->swipe->swipe->swipe ... and then ... find the extra-super-small button to turn on/off lights
- Sound for turn-by-turn navigation on the device but not on the mobile phone? Could not figure out how to do that?
- Why am I forced to ride with a virutal partner??
- I could not figure out how to show the radar-bar always on the screen, even if there is not car behind me (to distinguish between a not-connected radar and a connected radar).
- I also have a Specialized Tero E-Bike. The e-bike field shows a totally different remaining battery percentage than the bike does.
There is probably much more. And I am sure there is somewhere a sub-sub-structure in the menu from where you can click and swipe a couple of times to change a setting that you can't find again when you need to change it back.
What I really like are the large display, the map details, climb pro, GPS accuracy. But why does make Garmin it soooo hard to love their devices?
I give it a couple of days more but will then switch back to my Wahoo Elemnt.
Best,
Frank
