After running and installing the 12.15 update (Edge 1040 Solar), I can no longer select the German language. Only the English language is available. Does anyone have the same problem, or a solution?
Garmin likely updated the language bundles. Try connecting the unit to a PC and run Garmin Express it should offer the option to install the updated language bundles.
There ist no language update available.
Hi ... thank you very very much ... this solved the problem. THX ;-)
