Hello,
Is it possible to see POI on the map?
how do you manage them?
Thanks
Sorry I was conflating saved locations with POI's. They are actually two different things. The 1040 currently does not support importing POI's.
You can control at what map level the POI's from the maps show up.
That's a feature all the units all the way back to the 800 (at least) supported.
I suspect, if the 1040 doesn't support POIs (had the code for that removed), it will never support POIs.
I would not make the statement it will never be supported.
As Raimaker mentioned in his review the UI on the 1040 is completely new and not all things were re-implemented for day one.
We have seen this in other others such as some of the Di2 support. Here Garmin added some of it back in the recent updates and have said that more is coming back in the next release.
The spec page has no mention of POI's at all
