I have about 30 strava routes that I use again and again and they did not copy over from my 1030+.
When I add a new strava route it automatically syncs but how do I sync the old ones?
The quickest way maybe just to side load course.
Copy the the contents of the Garmin\Courses folder on the 1030+ to the Garmin\NewFiles folder on the 1040.
It wont sync already starred ones, only newly starred ones. I found if you go into Garmin connect app, courses, select the course and select "send to device" on each course you want to push, they then…
It wont sync already starred ones, only newly starred ones. I found if you go into Garmin connect app, courses, select the course and select "send to device" on each course you want to push, they then go over, 1 by 1
