The calories calculated on the 1040 is significantly different from that on the 1030 (not Plus). Same cycle, same sensors (ported across), same ride area similar av. speeds, climbs, etc. Generally on the 1030 the calories per mile would be close of 42. Same everything (given no 2 rides can be absolutely identical) but on 1040 so far calories per mile is always around 38. Which is actually 10%'ish change!
Only sensors are speed and cadence (cadence sensor being used does seem to have an impact on the calculated values). I appreciate it's not an absolute measure and just a number indicator more for comparison that explicit use but it suggests a different algorithm or weighting or something.
Anybody else noticed this or know why? (I have no idea about what happened on 1030+.
