In many tests I read that one of the new features of 1040 is its POI database and searching functions that are now extended to find easily water stops. I can't figure out where this function is. Or did I misunderstood something?
I spoke with Garmin and these point types will be included in the Cycle Map EU 2022.10 update.
Not sure of the release date for the update, but I would guess sometime in June based on previous years.
I was told from Garmin that the new Cycle Mape EU 2022 will only be released in November (I hope they mean November 2022)
Go to the home page
Select Navigation -> Search
I found a solution for me.
What is working with this solution:
What is not working with this solution:
How to do it? Simple, as it worked before with the POI Loader.
I downloaded a gpx file in OSM overpass turbo and exported all "drinking_water" (also "toilets") amenities of Switzerland into two GPX files. Then I downloaded two bitmap pictures signaling water and toilet and loaded all of this with the POI Loader to the Edge.
If you are interested in a detailed instruction, I can add some screenshots.
Hi Baselpower
I use the OpenTopoMap from https://openmtbmap.org/de/
In this map the Water Stops are includen (without search)
Hi Baselpower,
yes please.
I am very much interested in your workaround.
with edge 1030 I exported waterpoint gpx files to excel renaming to whatever it had to be and exported to .gpi file to be dropped in Garmin/POI map.
that worked fine.
Now with Edge 1040 nothing seems to work so would be happy to try your workaround...
Thanks in advance.
Kind regards,
Ronald
