2 bugs: Varia and HRMpro connection
On my last tour, yesterday I realized, that I can’t change the lightmodes of my non EU Varia 510 Radar with the Edge 1040.
And I have manually to connect my HRMpro heartrate monitor, even he is on the sensor list already. The edge don’t connect automatically to him.
  • Did you pair the RTL510 as light as well as radar?
    To pair as a light you need to put the RTL510 into pairing mode by holding the power button down until the LED turns purple and then search for a light
  • Yes I did already, otherwise I wouldn‘t see the available light modes.
  • Was the timer running when you were trying to change the modes?
    Is Light Beam Activated set to "Timer Start"
    If the timer is not running and the above setting is as shown then the UI will not reflect and changes you make to the lights in terms of light modes. It will continue to report the actual status of the lights which is Off.
    Try starting the activity timer or change Light Beam Activated to Device Power Up.
