The device is freezing during viewing and scrolling the map - only hard reset helps
Is anybody having such an issue?
Yes same issue here, map freezes after zooming :( version 12.15, only reset helps please help... i have upgraded from g1030 but i am sooo dissapointed :(
Bike maps of europa,doesnt matter which country or region - have tried Austria as well as Slovakia with different locations, always the same - after few moves on map the device completely freeze
Accessing…
Regardless of the fw version (2.11; 2.14; 2.15), the screen freezes and after a while the E1040 is reset. When I enter Navigation and click on the schematic course of the route, the device takes me to…
What map zoom level are you using?
If I tap minus sign on default map view 3 times it freezes every time. From the loaded route if I tap to show the route it freezes instantly without showing the map.
What regional maps are using?
In Garmin Express I see Map: Routable Cycle map of Europe 2021.20, I am trying to view my current location which is Slovakia. I was trying to install updates in Garmin Express but it fails every time
The screen freezes when using maps of Europe. I can send a video of how it's done. On the last Sunday, during the ride at the course, the freezing occurred several times. Currently, it does occur from time to time. However, this is frustrating and unacceptable !!!
That would be great if you could. You can send it to me via a Private message if you like. If that does not work I will send you my email address
OK. I request information. I will send a video or link to YT with this problem.
Same issue, I saw freezings using
(all videos are unlisted)
New garmin, software updated, profiles transferred, + 2 topo maps, then hard reset
