It changes to a rectangle sometimes.
We are aware of this problem and working on a resolution. We will provide an update when one is available.
It should be similar to what is above the front rings --/--
Bug? If the gear sensor is connected, then there's a black rectangle instead of a black square.
i have the same. Its meant to display the ratio you are i'm on the rear. Yet another bug!
I have reported this issue
I get the following black box in the Gears data field.
Is it a general mistake?
Could you link this data field, please?
I don't understand the question. Is oficial data field, GEARS.... If you select individual front o rear works.
Look here:
https://forums.garmin.com/sports-fitness/cycling/f/edge-1040-series/297219/why-is-there-a-black-square-in-the-gear-data-field/1436072#1436072
ah ok, duplicated post. I hadn't seen that one.
