Can anyone report if Garmin have fixed the issue that the 1030+ has with ridiculously long responses to changes in gradient?
Thank you for sharing your concerns about the undesirable lag in road grade. We want to share that we have a plan for an improved solution with consideration of both accuracy and responsiveness. Our engineers…
@Garmin-Mathew.
If you really believe that 10-15 seconds delay is considered “normal” - as the official statement from Garmin is trying to force-feed customers, then what does that say about my Edge 1000…
I currently have a wahoo element (full size) a karoo2 and now a 1040 solar. as of the 12.14 release the 1040 solar still has a ridiculous lag as compared to the other two. I really don't care too much…
@ looigi,
“FWIW: As a possible workaround, there are a couple of IQ gradient fields that I've used on other Edge units that work significantly better than the native gradient field. IDK about using them on the 1040, but it might be worth a look. One is Sensible Grade but I don't think it's compatible with the 1040 yet.”
Thanks for this suggestion. Have you used Sensible Grade on a 1030 Plus? I wonder if it can take the lag-plagued, gradient data from a 1030 Plus and spit out a ‘more acceptable’ 2-3 second delay display instead?
mcinner1 - What exactly are you saying here? I have just done a climb with the Data-Field still up, the Elevation Screen and ClimbPro was on. All 3 were showing exactly the same Gradient and Elevation all the way up.
Are you saying that ClimbPro takes precedent of the 1040 Gradient display and it supplies the Data-Field. I have to say the Gradient Data-Field did look more valid on the climb, not afterwards obviously. (This may have been wishful thinking, I only did the climb once.)
I created the Course with Komoot and the .gpx has the Elevation:
     <trkpt lat="46.954343" lon="7.082424">
        <ele>559.199008</ele>
        <time>2022-07-01T10:18:43.365Z</time>
      </trkpt>
Is it possible that the 1040 ClimbPro uses this to calculate Gradient and subsequently feeds it into the Data-Field during a climb? mcinner1 - What exactly are you saying here?
The gradient datafield works using the change of the measured barometric pressure as a function of distance, measured by speed sensor or GPS. it has nothing to do with Climb Pro and works even without a course loaded.
Climb Pro uses only the elevation profile of the loaded course as a function of the GPS measured position on the course. It only works with a loaded course and has nothing to do with the gradient datafield.
ClimbPro does report the average grade remaining on a climb, which comes from the course data, but this does not affected the grade data field whose value comes from using the barometric sensor and speed data input.
So my original statement is correct:
However, I use the ClimbPro and Elevation screens so I am still subjected to this crap.
Crap being the Garmin Gradient display, which is worse than useless.
But, ok if you see what Gradient is still to come on ClimbPro, that’s helpful.
The climbing pro graphic is as useless as the gradient. You’re half way up a hill before it even registers. What’s the point of implementing duff functionality if you then don’t try and fix it and defend it by saying “it’s normal”.
Ripp off
