Hey all,
Picking up a 1040 tomorrow. Will I have to manually redo all my screens?
Hey all,
The set-up process through the phone will import them.
Unfortunately for me only 2 of 5 profiles were imported, and only some of the fields were what they were on the 1030. IQ fields are now just generic timer fields. Loving Garmin.
IQ fields will not import as they may not exit yet for the 1040.
If you still have your existing unit you can try just copying the missing profiles over to the Garmin\NewFiles folder on the 1040
Bingo that helped. PHEW!
Sadly, IQ apps cannot be installed if they're not yet compatible with the 1040. So Humon Interval is dead, the company is out of business.
Wonder if there is a way to just manually move the IQ app and see if it works.
You can try side loading it. On the source unit look in the
Garmin\Apps folder for PRG files. Try just copying them to the Garmin\Apps folder on the 1040.
You would then need to add them back to your training pages.
The GarminDevice.xml file on the source unit can help identify the one you want or just move them all. If things blow up you can just delete them from the 1040.
Sensors moved over but no profiles (I have quite a few). Needed to have both my 1040 & 1030 connected to the phone app for it to ask to do it, I previously set up without the 1030 connected and it didn't prompt to copy anything over.
