Hallo,
i created my Custom POI file with some POIs inside and transfered the file to my Garmin1030 plus. Within the folder „Suchen“ i sehe the file and the individual POIs are included. Until this point everything is ok.
Now i want to use the POI while cycling.
I like to understand now :
1. ??? are all POIs in the folder „Suchen“ (search) now visible on the map ?? Do I need to make the POIs visible with a switch.
2. ???. Is ist possible to make the letter size of the POIs on the map larger , bolt ???
3. ??? Is it possible to generate an Alarm, when i reach or come next to an POI ??? I added a distance in the charcteristic of the Individualismus POIs, but I donot get an alarm yet.
Thanks very much for your answer.
