Auto Pause 1030 in all Activity profiles are set to a minimum of 10km/h even for MTB and it even does not go in auto pause.
There is no option to select auto pause when stopped as described in the manual. Updated already to Version 10.20.0.0 and made a new profile. In an old MTB profiel speed was set lower dan 10km/h but when I try to change again it goes to a minimum of 10km/h. This function worked fine in previous versions.
Top Replies
  • In an old MTB profiel speed was set lower dan 10km/h but when I try to change again it goes to a minimum of 10km/h. This function worked fine in previous versions.
    It‘s obvious that you‘re…
All Replies
  • The when stopped option shows up in my 1030. When your on the auto pause option screen, press Auto Pause Mode and there are three options. Off, When stopped and custom speed.
    It‘s obvious that you‘re mixing up two things:
    -Timer start mode: cannot be set manually below 10 km/h - but has nothing to do with Autopause
    -Auto functions: here you‘ll find Autopause. As stated, it has 3 options and you can set manually a value below 10 km/h - e.g. 5 km/h
    0 Former Member in reply to mcinner1
    Thanks, solved my issue!
