MaxRower - We are still investigating this. The fix for the battery percentage was not added to the recent update (8.00).
Workaround is very simple. Issue arise when the device goes into sleep by itself once charged. Then if you wake it up and use it immediately battery is stuck at 100%. To avoid this when you unplug the…
Or maybe Garmin could just fix this long long long standing bug so that 1000's of users don't have to remember a workaround to just get the device to accurately report battery level - just saying ;-)…
Workaround is very simple. Issue arise when the device goes into sleep by itself once charged. Then if you wake it up and use it immediately battery is stuck at 100%. To avoid this when you unplug the device after charging wake it up, then do a complete shupdown.
After that at power-up the battery indicator will work normally.
Really ?. My 1030 had the same 98% max charge issue for a month and only after the 8 update did it show 100%.
