No distance to next turn on map
My navigation map only shows the street I'm going to at the top.
Previously, it also displayed the distance to the next exit, which counted down in meters to the exit.
I don't see this anymore. Can someone tell me how to turn it back on? Is this profile-dependent?
Hopefully, someone can tell me how to fix this.
Thank you very much, Greetings, Hank
  • Hi,
    On the main page, got to navigation---> then courses----> then saved courses.
    You have to have at least one course in there. Do not clic on any of them yet.
    At the bottom right, you have 3 lines. Clic on them. On top of that new page, you will see: turn guidance, it should be on (green).
    Now, you can choose one of your loaded courses and you should see the distance to your next exit.
    Works the same for both my 1030+ and 1050.
    Michel
  • Thanks very much!!!!!!
