Edge 1030 Navigation stop working after update map 2025.10 sw 13.75
I installed by garmin express 7.25+axxxx a map update topo europe 2025.10 on my edge 1030, sw 13.75  , after a successful installation , navigation on my edge stop working ,city search did not work , an alert of incident detection is showed when i tried to see map . I did a hard reset , update more time map succesfully but not resolved issue. Garmin express after sync want to install again same map. Garmin & All could you help ?
  • After a new Hard RESET and a new map update topo active europe 2025.10 , I  closed successfully a GPS registration with device .  On Navigaton menu ,  when i tried to search to plan a trip , looking for a city (search city or poi) ),  typing name to search  my edge 1030 shut down ......I believe that topo active europe 2025.10 had problem , (file corrupted, search index ...) , Garmin Express after sync asked to update same map content......Again .... Garmin & All could you help ? It is possible to roll back to stable map version ? we need summer navigation  now
  • From AI Engine   I found
    The 2025.10 map update has caused issues on various Edge devices, including problems with rerouting and saved location navigation, especially when popularity routing is enabled 1.
    Some users have reported that disabling popularity routing temporarily resolves the issue.
    Others have noted that Garmin is aware of the bug and may be working on a fix, though no official patch or firmware rollback has been confirmed yet.
  • Update issues :
    After new Hard Reset and new Topo Active Europe 2025.10 update by Garmin Express  a) garmin express asked me to update with same map contents any time i asked for sync ....and b) in edge 1030 navigation menu if i tried to search for a  city or poi (city serach o poi search..) edge shut down ......  . I did an hard reset (that delete all data...)  and asked for a new map update topo active europe 2025.10 by sync....without any result , again edge shut down when i tried to search a city in navigation menu
    I asked to AI engine that answered : The 2025.10 map update has caused issues on various Edge devices, including problems with rerouting and saved location navigation, especially when popularity routing is enabled 1.
  • Solved with garmin support , by install on sd card these map (img , gma e unl file ) , need ti cancel on device all img, gma e unl file
    Garmin express did not install 47XXfiles and delete other file
    D4713090A.gma, img e unl
    D4728160A.gma, img e unl
    D6184160A.gma, img e unl
    D6185160A.gma, img e unl
    D9486050A.gma, img e unl
