touchscreen edge 1030 not responsive
I have an edge 1030 that was working well in several years, dayly use.
Since 2 weeks the screen is not responding to touch.  If i make a rest - boot up - with power button - then sometimes the touchscreen works. But not everytime.
i made:
- reset to factory settings
- opened the edge 1030 and disconnected the plug from dsplay - an put in again
- but the issue is the same:
most of the time the display is not responsive.  Some times after power on - all works fine.
What to do?
  • I have been having the same issue for the last few weeks. Some of the features, like the navigation button, are unresponsive.
    I noticed that the touch screen works perfectly fine without connecting with sensors.
    I also noticed it works fine after connecting with heart rate sensors. However, the touch screen does not respond properly after connecting with the speed sensor.
  • Thanks for the answer. I have cadence sensor connected usually. So i delet it - because it is not important for me.
    My Garmin Edge 1030 touchscreen woks somtimes after reset  (holding the power button for long time)
    But works not always.
    Now i have deleted the cadence sensor - i will report if this helps.
