The transfer of a self-created GPX track to my Edge 1030 Plus always fails.
I tried it with BaseCamp, Connect and USB cable, the file was always deleted after the restart
The Garmins are picky about the organization of the GPX files. Not all will work.
Basically, your file isn’t correct.
You could try converting your GPX file using something like:
https://www.gpsvisualizer.com/
You could also compare your file with files known to work (try Garmin or RWGPS.
The Garmins deletes the file so it won’t get stuck trying to convert bad files repeatedly.
