Map Update Caution
If Garmin Express indicates you've an (unexpected) Africa map update caution is advised before hitting the OK button as it appears, at least in my case, to have resulted in the dumping of my European map requiring its slow re-installation. Just a heads up, unless you're on the continent of Africa in which case GOOD NEWS, YOU'VE A MAP UPDATE!
