I uploaded openfietsmap.img and bbbike.img to Garmin folder but I don't see it in list of available maps. I tried several times but no go.HHow to solve this issue?
I use openfietsmap on my Edge 1030 plus also.
Have you seen the instructions:
GPS
Unpack gmapsupp_dd-mm-yy.zip and copy the garmin folder on a microSD card or copy the gmapsupp.img in a garmin folder on the internal drive of the GPS.
On modern Garmin GPS units you can give the gmapsupp.img a different filename.img
Do not copy different versions of the same mapset onto the micro SD card or GPS, otherwise the map will not show!
