Interval changes not saved
For some reason when I change my interval settings they are not stored.
This is how I change the settings:
Training -> Intevals -> Edit
Warming Up leave to off
Intervals -> Duration change to 00:02:00 and press the check button
Intervals-> Type: Open
Rest -> Duration change to 00:03:00 and press the check button
Rest -> Type: Open
Repeat -> change to 5 and press the check button
Cool down leave it to off
When I press the back button the overview shows the correct information.
Press again the back button and press Intervals again the settings are referred (duration = 00:01:00 and Rest = 00:02:00)
Am I doing something wrong or is it a bug (V6.40)
  • Issue "solved"
    Normally when changing from 00:02:00 to 00:03:00 I only changed the digit I had to change ("2" -> "3").
    Apparently that didn't work.
    But when I enter all digits "00:03:00" the change is accepted.
