The maps for Europe haven't been updated for over a year.
for example, Bryton updates its OSM maps every month.
In last year we have plenty of roads put into use.
When do you intend to update maps?
What about maps of other regions?
Any ETA of EU map update? This very old map is getting even older
They're here..... 2022.10 Euro maps are available in GE
I checked whether maps are up to date in Garmin Express.
I didn't know about this site:
https://my.garmin.com/mapErrors/report.faces
But how to report a year of changes?
I will try to do some reports…
What Maps do you currently have installed on the Edge 1030 Plus? You can check this by going to the menu > activity profiles > select a profile > navigation > map > map information
You can also report map errors here: How Do I Report a Garmin Cycle Map Error?
I'm taking about original Garmin Cycle maps delivered with Garmin Edge 1030 plus.
It is dated 2021.20 (July).
I will try to do some reports, but OSM map sourse is changing every day or week. Don't you know it?
Garmin Cycle maps are based on OSM map, so I suppose that on this base Garmin map could be updated just by 1 click or even by automatic algorytm.
It is impossible to report errors here How Do I Report a Garmin Cycle Map Error? Garmin | Zgłoś błąd mapy
because site has internal error.
As you can see bellow I filled garmin model but site shows error: this field is required. Therrefore reporting is impossible.
It is possible to click "no device - maps only" and then report an issue.
But reporting map changes is not the solution. All these changes are known. HERE maps and OSM maps are up to date. Only Garmin Cycle Map is OLD.
Thank you for trying the link. I am going to report the site errors on my end. The 2021.20 is the current version for the EU cycle map (2022.10 for North America). The EU cycle map will receive an update to 2022, it just has not been released yet.
I hope that will be soon as from last update my edge is not able to route via ferries. I fully understand, that to provide fresh map data to millions of people is a big overhead for the servers... But when a smaller companies can provide maps more frequently and have no issues with that, why Garmin is not able to do it?
I gave up on using the maps from Garmin a long time ago due to extremely tardy updates. https://www.openfietsmap.nl/downloads/europe has more frequently updated maps that can either be installed to a Garmin via Basecamp or downloaded as gmapsupp.img files to be directly copied to the Garmin folder on the GPS.
Thank you for letting us know, we understand this is not working as it should and are working on a fix. I apologize for the inconvenience.
