Hi Garmin,
1. How do I turn off the re-routing option as only options I get are the following even when when Popularity routing & Route Re-Calculation are set to Off (Promt with auto re-route, Prompt only, Auto re-route & Auto pause).
2. I can’t stop VP & it’s causing my issues with navigation because I leads me to think that is my point on the map & also keeps coming back if I get re-routed.
I need to follow a specific route with no detours as that would result in a DNF / DQ from the event.
Thanks for any advice
